How to use S32DS debugger 'Program Partition Command'
1,067件の閲覧回数
Maciek
Contributor V
I'm trying to use 'advanced' debugger settings to partition S32K144 EVB memory for EEPROM functionality. In S32DS for ARM v2.2. I have mixed results:
- started with default konfig. with FCFG1:DEPART showing 0xC (FlexNVM used as D-Flash)
- next I've tried set 'Enable Partitioning for the device' with 0204 code (all FlexNVM used for EEPROM)
- after clicking Debug - I could still see FCFG1:DEPART showing 0xC (unchanged)
- after a few experiments I've checked both options: 'Emergency Kinetis Device recovery...' and 'Enable Partitioning for the device' (with 0204) - and this worked. I could see FCFG1:DEPART showing 0x4.
- I've experimented with EEPROM functionality - and it has worked as expected
- then I've checked again 'Emergency Kinetis Device recovery' together with 'Enable Partitioning for the device' with code '020C' to restore FlexNVM as D-Flash. After 'Debug' I could see FCFG1:DEPART showing 0xF which is 'FlexNVM not assigned'. After that I could not change this field any more (no option 020C or 0204 works this time).
Can You explain how this function works ? What is the proper sequence of actions to successfully partition memory ?
Why am I seeing such erratic behaviour ?
Thanks for help
Maciek
941件の閲覧回数
danielmartynek
Hi Maciek,
This is PE Micro GDB Server Plug-In, please contact PE Micro Support if you have any issues with the plugin.
GDB Server Plug-In for Eclipse-based ARM IDEs | PEmicro plug-in for working with freely downloadable...
GDB Server Plug-In for Eclipse-based ARM® IDEs Debug Configuration User Guide, v.1.06
www.pemicro.com/downloads/download_file.cfm?download_id=459
FCFG1:DEPART = 0xC is not the default erased value.
So, I understand that it could not partition the MCU without mass-erasing it first.
Have you tried launching the FTFC partition command from the application itself?
Just to exclude any potential issues with the MCU.
BR, Daniel
942件の閲覧回数
danielmartynek
Hi Maciek,
BR, Daniel
