How to copy SDK source files into project rather than to link them
次の代わりに検索
1,620件の閲覧回数
jianyingchu
I am using the S32 KEAZ128 SDK in my project. By default, all the SDK files are linked to my project. Because multiple project are to use the SDK and make specific tweaks for each application, It necessitate the SDK files are copied into each project rather to be linked into. Is there any way to do it? Thanks, Jerry
タグ(3)
1,306件の閲覧回数
stanish
Hello Jerry,
I'd suggest you to create your custom SDK that will copy all the files into a project.
1) go to SDK Management dialog (menu Window -> Preferences -> SDK Management)
2) Click "Add..." to create a new SDK and enter Name, Version, Description
3) Browse to select SDK source path ("c:\NXP\S32DS_ARM_v1.3\S32DS\S32_SDK_KEA_1_0_0")
4) Select all / Copy all the sources and headers
5) Now your workspace contains a new SDK
6) You can create a new project now and your new SDK should be available in the list of SDKs so select it and finish the wizard.
Your project should now contain a copy of entire source folder structure (+ include paths):
Hope it helps.
Stan
2 返答(返信)
1,307件の閲覧回数
stanish
Hello Jerry,
Hope it helps.
Stan
1,306件の閲覧回数
jianyingchu
Hi Stanislav,
appreciate your reply very much. your solutions works great to me! BRs, Jerry
