How could CONST data will not be compiled to be immediate data in code?
1,114 次查看
elvan
I am working in a calibration projector. for realtime setting, I don't want that CONST data is compiled to immediate data.
what can I do .
in this case,  b = a is compiled to  b = 200  in ASM.
C:          const u16  a = 200
             b = a;
ASM:    14fc: 22c8       movs r2, #200 ; 0xc8
             14fe: 4b04       ldr r3, [pc, #16] ; (1510 <ini_fs_misc+0x24>)
             1500: 801a       strh r2, [r3, #0]
S32DS V1.3 + Win10
948 次查看
stanish
Hi elvan,
One solution could be to declare the const as a volatile. This way you basically disable compiler optimizations  for this const.
C: volatile  const u16  a = 200
Or access the value of the constant via pointer:
C:
const unsigned short a = 200;
unsigned short *pa = &a;
b=*pa;
Hope it helps.
S.
949 次查看
stanish
Hi elvan,
C:
b=*pa;
Hope it helps.
S.
948 次查看
elvan
Hi Stanislav.
Thank you very much , it's very useful.
948 次查看
elvan
Developing on the KEAZ128
