How build MPC5748G gcc cross compiler
danielnäslund
We're setting up our CI buildsystem and want to build the  gcc 4.9.4 cross compiler for our Linux docker container.
I've gotten the impression from https://community.nxp.com/t5/S32-Design-Studio/S32-Design-Studio-GCC-VLE-4-9-4-doesn-t-support-e-stm... that you have patched your gcc.
How can I build it using crosstool or other means?
mikedoidge
Hello @danielnäslund ,
You can download the latest Power Architecture GCC sources from here:
https://www.nxp.com/lgfiles/updates/S32DS/S32DS_PA_2017.R1_GCC.tar
Extract the tarball and you'll find the build scripts are included as well.
Follow the instructions in the README in the ‘source_release’ directory.
Let us know if you have trouble, but be aware that trying to build on oddball (either too old or too new) Linux distributions could be problematic. Something in the vicinity of RH5 or 6 should be ok.
Docker itself is not a problem. You can ask docker for just about any Linux distribution – so that’s the potential problem.
Mike
mikedoidge
Mike
