Example Project in S32 Design Studio 3.5
792 次查看
hemanths
Hello Friends,
I have recently installed the S32DS version 3.5. But I can't find any example project in the design studio. Can somebody help me how to access these example projects? I have attached the screenshot of the pop-up when I select the project from the example option.
Thanks in advance!
标记 (2)
754 次查看
lukaszadrapa
Hi Hemanth,
you need to install RTD package first. Please follow the steps in this guide:
https://www.nxp.com/document/guide/getting-started-with-the-real-time-drivers-rtd:GS-AUTOMOTIVE-RTD
Lukas
771 次查看
BGauthier
Good morning, Hemanths,
(Sorry, I don't have the right to attach picture)
In the project explorer window:
  • Right click->New project...
  • You will get a pop-up windows title "New Project" "Select a wizard"
  • Under "S32DS Projects", select "S32DS Project from Example" then "Next"
  • You'll get the following title in the pop-up window: "Create S32DS Project from example"
  • You can then search the project type/key word in the 'Enter search text' for instance M7
Bruno
768 次查看
hemanths
Hi Bruno,
I followed the steps you mentioned. But still, I can't find the example projects. I have attached screenshots of the pop-up window.
Thanks and Regards
Hemanth
755 次查看
lukaszadrapa
Hi Hemanth,
Lukas
