Error in services launch sequence PEmicro GDB Launch Failure : Another GDB Server debug session is alreadyusing the same Server Port number. To run simultaneous debug sessions, please specify a unique Server Port and GDBMI Port in the Debug Configuration
PEmicro GDB Launch Failure : Another GDB Server debug session is alreadyusing the same Server Port number. To run simultaneous debug sessions, please specify a unique Server Port and GDBMI Port in the Debug Configuration for each project. If another session is not running simultaneously, make sure that the pegdbserver_console and the arm-none-eabi-gdb processes have terminated.
Make sure you don't have the debug session running (terminate it). Otherwise, see GDB Client and Server: Unlocking GDB | MCU on Eclipse
I hope this helps,
Erich
The same thing applies to S32 Design Studio: have you checked your task list for another server running?
It would be pegdbserver_console.exe for P&E.
And check your launch configuration settings. It could be that your problem is this one: Solving “Launching: Configuring GDB Aborting Configuring GDB” | MCU on Eclipse
I hope this helps,
Erich
and How to execute Factory Reset on S32K144?
i push Reset button on board. but it is nothing.
i guess to reset RAM region.
i want to reset Flash region....
I do not speak well..
Thanks for taking my question.
