Does S32DS for PA have the function like Graph in CCS(not SPT graph)
1,000 次查看
eleclin
I want to graph the data in the ram, but I can find the function. Can S32DS do this like the graph function in CCS?
标记 (3)
858 次查看
jiri_kral
unfortunately - in S32DS  is not such feature. You can export data from memory view (and process it with gnuplot, scilab or other tool) or modify your code to be able produce usable data output. Somebody had similar question here:
Exporting Array/Memory data from S32DS to Host system ?
Jiri
