Could not install S32DS 3.4 and S32DS 3.5
hdlee
I installed my personal laptop PC with S32DS 3.4 and S32DS 3.5 because I wonder if S32DS 3.4 and S32DS 3.5 installed successfully.
After that, I uninstalled S32DS3.4 and S32DS 3.5 in my personal laptop PC.
When I reinstalled S32DS 3.4 and S32DS 3.5 in company laptop PC, I encountered a rollback problem.
I attached two install log files. when I saw the installation log files, I found same issue just like this.
"Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)"
Please help me to solve this issue. I urgently need your help to solve this problem to support customer Automotive MCU S32K series as distributor FAE.
Mehul_Patel_NXP
Hi, @hdlee ,
Please make sure that you have administrator right privileges while installing the S32DS.
Also, if you face issue related to it, please check with the your company's your company's IT team if something is blocking because of firewall or restriction and make sure you have administrator right while installing.
Please follow the S32DS guide while installing S32DS: https://www.nxp.com/webapp/Download?colCode=S32DSIG
Thank you. Kind regards.
- Mehul Patel
Mehul_Patel_NXP
Hi, @hdlee ,
- Mehul Patel
hdlee
Okay, based on your guideline, I will contact with our company's IT members. so, I will close this ticket.
