变量自动补全 设置
变量自动补全 设置
JonZhou
hello,
Where can I set the variable completion function?(S32DS for ARM,)
It would be even better if there were specific screenshots, thank you!
lukaszadrapa
Hi @JonZhou
please take a look at:
https://stackoverflow.com/questions/6912169/eclipse-enable-autocomplete-content-assist
It's jut not Eclipse->Preferences but rather Window->Preferences.
Lukas
JonZhou
Hi,@Lukas
非常感谢你的回答,但是按照如图所设置,仍然不能自动补全;请问还需要设置哪些?
lukaszadrapa
Hi @jiri_kral , would you  know what's going on? Can you please help?
JonZhou
有人可以解答吗?
