what is the procedure to handle unused port pins of part MC9S12XET256MAG ?
775 次查看
kumara
614 次查看
lama
The http://www.nxp.com/docs/en/application-note/AN3262.pdf written for S12XD family devices can be used to better understand design. Of course, there are some differences between devices but the HW design is almost the same and technical approach is common.
The Chapter 14 describes Managing Unused Pins.
Ladislav
614 次查看
danielmartynek
Unused pins can be configured as inputs or outputs. But because internal pull resistors are active only in the input mode, it is better to set them as inputs and enable pullups. Many pins have pullups enabled by default, out of reset.
