Hi all.
My problem is with HCS12's UART that do not detect a break even if I enable break detect feature (SCIACR2.BKDFE=1 and interrupt enabled SCIACR1.BKDIE=1)
Please help me!
Or share Lin example code that uses break feature.
Did you set AMAP bit to get access to SCIACRx registers?
As well you can detect break receiving 0 in data register along with FE bit set.
