question on input-capture and true-time simulator
703件の閲覧回数
holder
Folks,
 My target is MC9s12DP256B
 I am using Code Warrior v5.1 for HCS12.
My Question:
Is it possible to send data into the input-capture channel 0 running with the full chip simulator?
I tried using the "stimulator component" with the following sample script from the docs:
def a = TIMER.PORTTBit0;
PERIODICAL 4000,500:
1000 a = 1;
3000 a = 0;
END
When executed I do not see the interrupt 8 capture0Handler ISR get called in my code. The code works fine on physical target but we don't have enough boards yet.
Obviously I am doing something wrong in the simulator. Thanks for any advice.
bob
513件の閲覧回数
kef
Specialist I
Try replacing TIMER.PORTTBit0 with PIM.PORTTPin0. It worked for me.
You should use Inspect component to see if particular object is implemented. I didn't found TIMER object, only Ect and port integration module PIM.
514件の閲覧回数
kef
Specialist I
513件の閲覧回数
holder
Yes. that worked fine. thank you for the solution.
bob
