on reset --- RTC in 52235
搜索替代
742 次查看
Latha
I am working on these issue from couple of days and i am not able to figure why it is happening so.
On reset all the RTC registers (seconds,minutes,hours days,alm  ) are reseting to zero. In the manual it is given as the values will be  arbitary .So I expected  on reset the values would be same before the shutdown but it is reseting on each power on and also reset. Can some body explain about this .
my plan is to provide back up using  battery for the RTC and make it to run continously to maintain real time .
I am also including the intailizatiopn code here.
MCF_CLOCK_RTCDR = ( (SYSTEM_CLOCK_KHZ * 1000 ) )  /* for configuring tjhe clock */
MCF_RTC_RTCCTL = (MCF_RTC_RTCCTL_EN ) ;
MCF_SCM_PPMRL &= (0xFFFFEFFF)  ;                           /* enables the RTC*/
Please help me......i am stuck at this simple thing............
Thanks for your time
111 次查看
Xbot
Registers will get 0's during reset. why do you shutdown your micro if you want it real-time though? If you want to maintain value when its OFF, you should flash it in EEPROM.
