launch flash command,   fallowing program cann't be executed
1,175件の閲覧回数
gogoranger
hi. i have a problem.
After i launch flash commad. the fallowing program cann't be executed( i use LED_OFF to indicate command complete, but LED do not off, and interrupt cann't enable ). so i have to reset my MCU. and after reset, the flash command is executed Successfully.
fallowing is my code:
LED_ON(D27);
if(!FCLKDIV_FDIVLD){
FCLKDIV = 0x03;
while(!FSTAT_CCIF)
if(( FSTAT_ACCERR || FSTAT_FPVIOL )){
FSTAT = 0x30;
FCCOBIX = 0;
FCCOB = 0x0A7F; /*erase sector */
FCCOBIX = 1;
FCCOB = 0x4000;
Erase_ROM();
LED_OFF(D27);
#pragma CODE_SEG __NEAR_SEG ramcodeseg
void Erase_ROM(void) {
asm
PSHC // remember I-bit state
SEI // disable interrupts
FSTAT = 0x80; //launch command
while(!FSTAT_CCIF); //wait for done
asm PULC; // restore I-bit
#pragma CODE_SEG DEFAULT
can anyone helps me?thanks!!!!
6 返答(返信)
979件の閲覧回数
kef
Specialist I
Did you check what address Erase_ROM is allocated at? In case ramcodeseg placement is not defined in PRM file, Erase_ROM probably ends in flash, which is wrong. Your PRM file should have line like below in the PLACEMENT section:
   ramcodeseg INTO RAM;
979件の閲覧回数
gogoranger
hi! thank you for your help!
fallowing is my prm file:
RAM2           = READ_WRITE    0x3000 TO   0x3FFF ALIGN 2[1:1];
ramcodeseg        INTO  RAM2;
fallowing is my map file:
     Name               Module                                     Addr   hSize   dSize     Ref    Section
                          Erase_ROM                                 2000       F        15          2   ramcodeseg
is there any else possible error?
979件の閲覧回数
gogoranger
hi! i think i have no error in prm file.
could you give me more suggestion to solve my problem?
my flash command can be accomplish, but fallowing line in program can not be execute.
thank you very much!!!!!!!
979件の閲覧回数
kef
Specialist I
Do you have no warning about missing prototype? Are Erase_ROM and surrounding __NEAR_SEG block #pragmas defined before Erase_ROM is called? It is not enough to put just prototype above caller. It may be that Erase_ROM is called with CALL instruction, while it returns with RTS...
979件の閲覧回数
gogoranger
hi!
you are right!! it works!!
i use "FAR_SEG" replace "NEAR_SEG"
#pragma CODE_SEG __FAR_SEG ramcodeseg
thank you!!!
979件の閲覧回数
gogoranger
sorry, i forgot to mention that my MCU is MC9S12XF512
