VSPU voltage acquisition of MC9S12ZVC
904 次查看
872454246
VSUP voltage acquisition of MC9S12ZVC,When the ADC carries out VSUP voltage acquisition,The VSUP voltage is several times the ADC value,I didn't see it in the manual.You can tell me if you know where it is.
Thank you!
标记 (1)
817 次查看
872454246
Pin Input Divider Ratio2
RatioVSUP = VSUP / VADC
5.5V < VSUP < 29 V
Ratio VSUP = 9
818 次查看
872454246
5.5V < VSUP < 29 V
Ratio VSUP = 9
