Use the S12ZVML-MINIBRD Board to change the motor speed
搜索替代
682 次查看
519315342
Can I modify the code to change the motor speed?
what is the code to control the speed of the motor ? And how to modify the code can control the motor speed?
349 次查看
stanish
as far as I know this motor control application can be controled from FreeMASTER visualization tool via OSBDM serial COM. (see the screenshot below)
FreeMASTER .pmp file should be part of the demo application.
Hope it helps.
Stan
350 次查看
stanish
Hope it helps.
Stan
