hi,
I have a problem with PLL, follows are the program:
void PLL_Init(void)
CPMUOSC_OSCE = 1; /* enable ext osc */
Initialise the system clock from a 16 MHz Crystal,
24 MHz Bus CLK (48 MHz VCO, 48 MHz PLL)
CPMUSYNR = 0x00 | 0x05; /* VCOFRQ[7:6], SYNDIV[5:0] */
CPMUREFDIV = 0x00 | 0x03; /* REFFRQ[7:6], REFDIV[3:0] */
CPMUPOSTDIV = 0x00; /* POSTDIV = 0 FPLL = FVCO */
while(!CPMUFLG_LOCK); /* wait for VCO to stabilize*/
//Service_WD();
CPMUCLKS_PLLSEL = 1; /* Switch clk to use PLL */
It stops at "while(!CPMUFLG_LOCK); " , I have checked the value of REFDIV and SYNDIV, they are right the value programmed, and I have checked the EXTAL pin;
Is something wrong with my program? or something wrong with the hardware?
please help me ! amd sorry for my poor english!
There seems to be problem with incorrectREFFRQ bit fields in the CPMUREFDIV register.
If fOSC=16MHz and REFDIV is 3, then you get fREF=4MHz. In this case REFFRQ[1:0] = 01 (see Table 10-2. in the S12G ref manual), but you have it '00' there.
So it should be like this:
CPMUSYNR = 0x05;
CPMUREFDIV = 0x83;
CPMUPOSTDIV = 0x00;
In the main code you can use a codeline which will route the bus clock to the external pin ECLK, so you can check the signal on scope:
ECLKCTL_NECLK = 0; | // enable ECLK output (bus clock is visible on pin PB0 for TWR-S12G128, PS7 for TWR-S12GN32) |
// default clock setup after reset is PEI mode 6.25MHz BUSCLK |
Also you can check appnote AN4455 which comes with the SW packt. There you can find Demo Labs such as the one demonstrating how to configure System Clocks.
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4455.pdf
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4455SW.zip
iggi
Thanks for your reply, I have found why the PLL did not work.
I<mc9s12g family reference manual and data sheet> ,page 354
The Phase Locked Loop (PLL) has the following features:
• highly accurate and phase locked frequency multiplier
• Configurable internal filter for best stability and lock time.
• Frequency modulation for defined jitter and reduced emission
• Automatic frequency lock detector
• Interrupt request on entry or exit from locked condition
• Reference clock either external (crystal) or internal square wave (1MHz IRC1M) based.
• PLL stability is sufficient for LIN communication, even if using IRC1M as reference clock
I changed the Oscillator to crystal, then the PLL works.
