Multiplying two eight bit numbers numbers
2,074件の閲覧回数
JohnnyP
I am reading two voltages into the A/D, and I want to multiply them.
For example, 1.5v x 1.5v = 2.25v
2.25 x 255/5 = 115 = $72
1.5 x 255/5 = 77 = $4C
$4C x $4C = $1690 = 5776 = 76 x 76
How to get $72 from $1690?
5 返答(返信)
475件の閲覧回数
kef
Specialist I
multiply your product by 5, then divide by 255.
475件の閲覧回数
JohnnyP
Kef:
Lots of products, which one?
475件の閲覧回数
kef
Specialist I
I replied before you send your second post. I meant product $4C x $4C = $1690. You asked how to get ~$72 from $1690. Answer is multiply it by 5, then divide by 255.
ADcode of 1.5V, having 5V AD reference is sort of this
1.5V
----- * $FF
  5V
Similarily ADcode of 1.5V*1.5V=2.25V, with 5V reference is sort of this
1.5V*1.5V
------------- * $FF
    5V
What if we replace 1.5V in this expression with reverse expression
$4C
-----*5V ~ 1.5V
$FF
Full expression becomes
$4C * 5V    $4C * 5V         1
-----------  * ------------  *  ------ * $FF
      $FF          $FF            5V
or
$4C * $4C  * 5V
$FF
Message Edited by kef on 2008-12-25 01:34 AM
Message Edited by kef on 2008-12-25 01:35 AM
475件の閲覧回数
JohnnyP
Wow, that's great. I only worked on it for eight hours. (arg).
475件の閲覧回数
JohnnyP
Hooray, I got it. Tom Almay has a section on fractional scaling in his book that gave me the clue.
I'll post my code later. I ignored a couple of remainders, and maybe it could be simplified, but it's pretty close.
For those that want to work it out, convert the A/D reading into thousands of millivolts.
For an input of 1.5v = $4D
($4D x $1388)/$FF = $05D2 = 1490mv
If the other input is 2.75v = $8C
($8C x $1388)/$FF = $0AB9 = 2745mv
Then ($05D2 x $0AB9)/$03E8 = $0FFA
Then ($0FFA x $33)/$03E8 = (tadaa)...$D0...
Note that $33 is $FF/5
Takes a lot of EMUL and EDIV's. Good thing the HC08 I was going to use didn't have enough pins for the job.
