I am using PH2,PH3,PJ6 & PJ7 of MC9S12XEP100 for glowing LED using 74HC04 Hex Inverter.
Initially when I power the board all four LEDs are ON by default.
LED PJ6 & PJ7 are working as expected but PH2 & PH3 LEDs are continuously glowing even by giving Data on that pin as continuously low.
I have checked the hardware connections & everything is fine there.
So what could be the reason behind this?
Can you disconnect the 74HC04 and check the outputs.
There is only one difference between PTJ6/7 and PTH2/3.
PTJ6/7 have internal pull-up resistor enabled by default whereas PH2/3 don't.
PH2/3 are floating inputs out of reset.
Do you use any alternative function of the pins (SPI, SCI)?
