MC56F8006 PWM generator
Search instead for
edjiang
I need to generator 6-channel PWM outputs in complementary mode. This is my first time using MC56F8006 and I didn't find any app-note on this. Does anyone have a simple example of PWM generation? So that I can take reference and modify it according to my application. Thanks in advance!
Ed
Tags (2)
khalil001
I am using the MC56F8006 to generate PWM now, and I have the same issue.
Have you solve this issue?
Could you see the PWM waveform on the corresponding output pins?
Could you help me? Thank you very much!
CarlosCba
Hi Ed,
I new with the MC56F8006 and I have the same issue. Could you do your code work? Can you post it?
Thanks in advance.
khalil001
peter_pinewski
If you are using Codewarrior, you can get example code through processor expert.  Note, the MC56F8006 has the same PWM as other DSC devices such as 56F8013.
Here is an example of the PWM intialization in processor expert for complementary PWM on the 56F8013
**     Method      :  PWM1_Init (component Init_PWM)
**     Description :
**         Peripheral Initialization Beans provide a low-level
**         hardware approach to initialize registers of the
**         peripheral module. They are intended for experienced
**         users.
**     Parameters  : None
**     Returns     : Nothing
void PWM1_Init(void)
  /* PWM_PMCTL: LDFQ=1,HALF=0,IPOL2=0,IPOL1=0,IPOL0=0,PRSC=0,PWMRIE=0,PWMF=0,??=0,??=0,LDOK=0,PWMEN=0 */
  setReg16(PWM_PMCTL, 4096U);
  /* PWM_PMFCTL: ??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,FIE3=0,FMODE3=0,FIE2=0,FMODE2=0,FIE1=0,FMODE1=0,FIE0=0,FMODE0=0 */
  setReg16(PWM_PMFCTL, 0U);
  /* PWM_PWMCM: ??=0,CM=800 */
  setReg16(PWM_PWMCM, 800U);
  /* PWM_PWMVAL0: VAL=400 */
  setReg16(PWM_PWMVAL0, 400U);
  /* PWM_PWMVAL1: VAL=400 */
  setReg16(PWM_PWMVAL1, 400U);
  /* PWM_PWMVAL2: VAL=400 */
  setReg16(PWM_PWMVAL2, 400U);
  /* PWM_PWMVAL3: VAL=400 */
  setReg16(PWM_PWMVAL3, 400U);
  /* PWM_PWMVAL4: VAL=400 */
  setReg16(PWM_PWMVAL4, 400U);
  /* PWM_PWMVAL5: VAL=400 */
  setReg16(PWM_PWMVAL5, 400U);
  /* PWM_PMDISMAP1: DISMAP=4369 */
  setReg16(PWM_PMDISMAP1, 4369U);
  /* PWM_PMDISMAP2: ??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,DISMAP=17 */
  setReg16(PWM_PMDISMAP2, 17U);
  /* PWM_PMDEADTM0: ??=0,??=0,??=0,??=0,PWMDT0=32 */
  setReg16(PWM_PMDEADTM0, 32U);
  /* PWM_PMDEADTM1: ??=0,??=0,??=0,??=0,PWMDT1=32 */
  setReg16(PWM_PMDEADTM1, 32U);
  /* PWM_PMCCR: ENHA=0,nBX=0,MSK=0,??=0,??=0,VLMODE=0,??=0,SWP45=0,SWP23=0,SWP01=0 */
  setReg16(PWM_PMCCR, 0U);
  /* PWM_PMOUT: PAD_EN=0,??=0,OUTCTL=0,??=0,??=0,OUT=0 */
  setReg16(PWM_PMOUT, 0U);
  /* PWM_PMICCR: ??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,ICC2=0,ICC1=0,ICC0=0 */
  setReg16(PWM_PMICCR, 0U);
  /* PWM_PMSRC: ??=0,??=0,CINV5=0,CINV4=0,CINV3=0,CINV2=0,CINV1=0,CINV0=0,SRC2=0,SRC1=0,SRC0=0 */
  setReg16(PWM_PMSRC, 0U);
  /* PWM_PMCFG: ??=0,DBG_EN=0,WAIT_EN=0,EDG=0,??=0,TOPNEG45=0,TOPNEG23=0,TOPNEG01=0,??=0,BOTNEG45=0,BOTNEG23=0,BOTNEG01=0,INDEP45=0,INDEP23=0,INDEP01=0,WP=0 */
  setReg16(PWM_PMCFG, 0U);
  /* PWM_PMFSA: FPIN3=0,FFLAG3=0,FPIN2=0,FFLAG2=0,FPIN1=0,FFLAG1=0,FPIN0=0,FFLAG0=0,??=0,FTACK3=1,DT5=0,DT4_FTACK2=1,DT3=0,DT2_FTACK1=1,DT1=0,DT0_FTACK0=1 */
  setReg16(PWM_PMFSA, 85U);            /* clear fault flags */
  /* PWM_PMFCTL: ??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,FIE3=0,FMODE3=0,FIE2=0,FMODE2=0,FIE1=0,FMODE1=0,FIE0=1,FMODE0=0 */
  setReg16(PWM_PMFCTL, 2U);
  /* PWM_PMCTL: LDOK=1 */
  setReg16Bits(PWM_PMCTL, 2U);         /* set LDOK bit */
  /* PWM_PMCTL: PWMEN=1 */
  setReg16Bits(PWM_PMCTL, 1U);         /* set PWMEN bit */
  /* PWM_PMCTL: PWMF=0 */
  clrReg16Bits(PWM_PMCTL, 16U);        /* clear PWMF flag */
/* END PWM1. */
edjiang
Hi Peter,
Thanks for your reply. Yes I am using CodeWarrior, but I am not familiar with so call processor expert. I modify the code you post and also enable the PAD_EN so I can measure the PWM with a oscilloscope. Unfortunately, I didn't see the PWM waveform on the corresponding output pins. I attach the complete code. What can be the problem in the code?
Ed
#include "CPU.h"
#include "MC56F8006.h"
typedef unsigned int word;
#define setReg16(RegName,val) (RegName = (word)(val))
#define setReg16Bits(RegName, SetMask)                           (RegName |= (word)(SetMask))
#define clrReg16Bits(RegName, ClrMask)                           (RegName &= (word)(~(word)(ClrMask)))
void PWM1_Init(void);
  setReg16(PWM_CTRL, 4096U);
  //setReg16(PWM_PMFCTL, 0U);
  setReg16(PWM_CMOD, 800U);
  setReg16(PWM_VAL0, 400U);
  setReg16(PWM_VAL1, 400U);
  setReg16(PWM_VAL2, 400U);
  setReg16(PWM_VAL3, 400U);
  setReg16(PWM_VAL4, 400U);
  setReg16(PWM_VAL5, 400U);
  setReg16(PWM_DMAP1, 4369U);
  setReg16(PWM_DMAP2, 17U);
  setReg16(PWM_DTIM0, 32U);
  setReg16(PWM_DTIM1, 32U);
  setReg16(PWM_CCTRL, 0U);
  setReg16(PWM_OUT, PWM_OUT_PAD_EN);
  setReg16(PWM_ICCTRL, 0U);
  setReg16(PWM_SCTRL, 0U);
  //setReg16(PWM_PMCFG, 0U);
  setReg16(PWM_FLTACK, 85U);            /* clear fault flags */
  setReg16(PWM_FCTRL, 2U);
  setReg16Bits(PWM_CTRL, 2U);         /* set LDOK bit */
  setReg16Bits(PWM_CTRL, 1U);         /* set PWMEN bit */
  clrReg16Bits(PWM_CTRL, 16U);        /* clear PWMF flag */
/* END PWM1. */
int main(void)
  PWM1_Init();
  for(;;)
edjiang
my target name is: SDM_pFlash
edjiang
this is my code which doesn't work.
void main(void)
   PWM_CMOD = 1000; // in this application,it's period of PWM, i.e. Time
   PWM_CNFG = 0; //center-aligned complementary PWM
   PWM_DTIM0 = 0x08;//deadtime insert
   PWM_DTIM1 = 0x08;
   PWM_OUT = PWM_OUT_PAD_EN;
   PWM_ICCTRL = PWM_ICCTRL_ICC2 | PWM_ICCTRL_ICC1 | PWM_ICCTRL_ICC0;
   //pulse_width = PWM_MODULO / 100 * duty_cycle ;
   PWM_VAL0 = 100;
   PWM_VAL1 = 800;
   PWM_VAL2 = 100;
   PWM_VAL3 = 800;
   PWM_VAL4 = 100;
   PWM_VAL5 = 800;
   PWM_CTRL = PWM_CTRL_LDOK;
   PWM_CTRL |= PWM_CTRL_PWMEN;
  for(;;)
