Hi, I'm using NXP Lin stack for S12ZVML64 as Slave.
I want to ask few things about LIN No Header & LIN Header only No Data.
1. I'm having my ECU in running mode but I'm not transmitting any Header from CANoe. In such case how can I show this on CANoe
2. I'm only transmitting Header and no Data from CANoe in such case how does the Slave responds to it and how can I show this on CANoe.
Thanks in advance
Abhijit.
已解决! 转到解答。
Hi itsnewforme,
1. When we say that we are sending only header from CANoe with no Response. Is that simply means that our ECU(Slave) is off and only CANoe is running?
=> This means is Slaves existed on the bus and no response or the slave doesn't exist on the bus.
2. The Master(CANoe) sends the header and Response is either sent by Master or Slave.
=> I have a note: when the Master(CANoe) is master then there is no other master on the bus.
Dan
Thank you so much @nxf78987 . I just want to confirm one thing.
When we say that we are sending only header from CANoe with no Response. Is that simply means that our ECU(Slave) is off and only CANoe is running. Because as per the understanding the Master(CANoe) sends the header and Response is either sent by Master or Slave.
Thanks you so much once again for helping with the canoe_test.zip
Hi itsnewforme,
Dan
Hi itsnewforme,
Dan
Hi itsnewforme,
This is an example of CANoe's configuration(Attached) that has been used to test.
Dan
