How to realize exp() function or sigmoid() function
次の代わりに検索
811件の閲覧回数
maxxu
   I want to implement the sigmoid function,but, It appears that the function does not exist in the library,
   I use the Automotive Math and Motor Control Library Set for NXP MC9S12ZVM devices.
   Does the exp()function exist in the library? or,How should I implement it with other tools
   This algorithm, I hope to have as fast calculation speed as possible。
        thank you
773件の閲覧回数
pachamatej
if you don't care about CPU load, then I would follow standard programming patterns for math implementation. Otherwise, I'd recommend to calculate a lookup table offline (e.g. using MS Excel) and then use it in the MCU. Polynomial approximation is also an option. The two techniques mentioned can be realized with support of the AMMCLib (GFLIB_Lut1D and MLIB functions such as Mul, Add, etc.).
Matej
2 返答(返信)
774件の閲覧回数
pachamatej
Matej
790件の閲覧回数
maxxu
Can someone help me?
