How to change the BLDC MOTOR rotational direction in S12ZVML-MINIBRD demonstration code?
ShuZ
Hello Mr. or Ms.,
I am now trying to use S12ZVML-MINIBRD to control a water pump, but I don't know how to change the motor rotational direction in demonstration code(S12ZVML-MINIBRD_BLDC_Sensorless_LIN_CW_IDE).
there is a easy way to change the motor rotational direction in physical side, which is change the U/V/W wiring connection, but is there any other solution from software side?
this is my first time in BLDC motor control area.
Thank you very much.
danielmartynek
Hello @ShuZ,
There is no such option, the code supports only one direction.
As you already mentioned, you can switch two phases to change the direction.
BR, Daniel
ShuZ
Understood, Thank you very much!
