Devkit S12ZVC : CANH stucked High
951件の閲覧回数
luca_ferrario
I've got a problem with the CAN bus, I've configured the MSCAN0 with code warrior expert (bit rate: 250 kbit). The system works fine in loop back mode: I can send data and the event CAN1_OnFullRxBuffer() is called, tha masks also work fine. I've got a problem when I want to use the CANPHY with CANH and CANL pins of the board: the CANH pin is stucked at high voltage! :smileysad:
I configured the CANPHY in this way:
CP0CR_CPE = 1; //Module Enable
CP0CR_SPE = 1; //Split Enable
and the M0C0RR[2:0] to 000
Did i miss something in the configuration of the CANPHY?
I've also tried to probe the data between CANPHY and MSCAN0 with the M0C0RR[2:0] configuration 0b100, in order to use the pins TXCAN0 and CPRXD0 as probes.
Channel 0: MSCAN0 TXCAN
Channel 1: MSCAN0 RXCAN
Channel 2: CANPHY0 CANH
Channel 3: CANPHY0 CANL
The RX data is coming from a PCAN simulator, if  the simulator is stopped no data is present on channel1 and channel 3.
Thanks for your help!
タグ(3)
2 返答(返信)
863件の閲覧回数
luca_ferrario
I think I found the issue!
I have a problem with processor expert generation, cause I've downloaded an example that is not generated with the expert and with these libraries and seem to work fine:
#include <hidef.h>
#include "derivative.h"
void PLL_init(void){
CPMUCLKS_PLLSEL = 1; //FBUS = FPLL/2. FBUS = 32MHz,
CPMUREFDIV_REFFRQ = 1; //Reference clock between 2MHZ and 6MHZ.
CPMUREFDIV_REFDIV = 0x1; //FREF=8/(1+1) = 4MHZ
CPMUSYNR_VCOFRQ = 0x1; //FVCO is between 48MHZ and 80MHZ
CPMUSYNR_SYNDIV = 0x7; //FVCO = 2xFREFx(SYNDIV+1) = FVCO = 2x4x(7+1) = 64MHZ
CPMUPOSTDIV_POSTDIV = 0x0; //FPLL = FVCO/(POSTDIV+1). FPLL = 64MHZ/(0+1) FPLL = 64MHz
CPMUOSC_OSCE = 1; //External oscillator enable. 8MHZ. FREF=FOSC/(REFDIV+1)
while(!CPMUIFLG_LOCK){} // Wait for LOCK.
CPMUIFLG = 0xFF; // clear CMPMU int flags - not needed but good practice
There is a way to generate a functional CAN example with processor expert?
Cause I've generated the rest of my code with processor expert... :smileysad:
thanks!
863件の閲覧回数
dianabatrlova
Unfortunately, there is no CAN example with Processor Expert.
I recommend you to look at AN4975 https://www.nxp.com/docs/en/application-note/AN4975.pdf
By PLL_init() function you configured the clock frequency but you can also configure it by processor expert.
Diana
