CANRIER/CSCIE interrupt
1,558件の閲覧回数
patti
Hi, am having a problem with CANRIER/CSCIE
when I set
CANRIER = 0x7F;
and try to transmitt to a CAN-network that is not connected, the debugger says Event Occured.
What should I do?
I have redirrected all CAN error interrupts to a xgate routine.
Thanks In advance
671件の閲覧回数
Nabla69
Contributor V
If the CAN node is not connected to a network, nobody will acknowledge the transmission.
When there is not ACK, a Receive Error occurs, incrementing the RX ERROR counter.
After a while, the module will switch to Error Passive and then Bus Off stopping all transmission.
Chico.
