Rapid IoT sensor integration
搜索替代
1,477 次查看
nxf64834
Is it possible to do the following using rapid Iot:
1.  Interface MAX30100 heart rate sensor with rapid IoT and somehow send the data of this sensor to atmosphere cloud?
Is it correct that on atmosphere cloud, we can only see data of default integrated sensors with rapid IoT?
Thanks in advance
1,458 次查看
estephania_mart
It used to be possible as it is mentioned here, but as the support for the Atmosphere Cloud has changed, you will need to check as well with their forums  to confirm about this.
I believe that it is similar to this post there , still, you will need to confirm with them if this is still possible.
Regards ,
Estephania
