Getting Start with Rapid IoT Kit on MCUXpressoIDE
2,556件の閲覧回数
ashokfair
Hi Everyone,
Here we going to see the basic "Hello World" sorry  "Ashok World" demo with MCUXpressoIDE
Tools Required:
MCUXpressoIDE -> Download it from here
SDK for Rapid-IoT-Kit -> Download it from here
Rapid IoT Kit
Steps to follow:
-> Import "hello world" project from SDK examples.
-> In the advanced settings page, uncheck the two options redirect SDK “PRINTF” to C library “printf” and Include semihost Hardfault handler and check the option Redlib: Use floating point version of printf, then press Finish.
Add below code after "Init_Display()" in hello_world.c file
    /* Display a Message */
    GUI_SetFont(&GUI_Font8x18);
    GUI_SetBkColor(GUI_WHITE);
    GUI_Clear();
    GUI_SetColor(GUI_BLUE);
    GUI_DispString("\n Rapid IoT\n\n");
    GUI_DispString(" Hello World!\n\n");
Then compile your project in-case if you get below errors
Fix it by replacing " THCI_Debug" by "printf"
After compilation success , Generate your ".bin" file like shown below
Press & hold  Top-Left button (SW3) then reset the kit to enter into USB flash mode.
flash the bin into your Rapid Kit by simple drag and drop.
Text "Hello World" will be displayed on your Rapid IoT Kit
To set image use this line "GUI_BMP_Draw(_ashok_bmp111, 0, 0);"  BMP image should be in RGB(1,1,1) 4bit format.
Download source here https://gitlab.com/mcucodes/rapid-iot-k64f-ashok-world
Thanks All,
Happy Coding!
Ashok R
www.ashokr.com
1,866件の閲覧回数
wenchen-b37495
Could we run this in a debug session in MCUExpresso directly instead of flashing the bin?
1,866件の閲覧回数
javierasolorzan
Hi Ashok,
  Thank you for sharing this with the community. If you are not following our community yet, you can do so by clicking on the " follow" button on the upper right hand corner of your dashboard. If you have any problems, please let me know. We would love to have as a part of our community. Thanks again and take care.
Javier
