how to generat kernel.itb file with kernel Image & kernel.dtb files
次の代わりに検索
7,835件の閲覧回数
srinivasreddyre
I am working on  NXP board Model: LS1012A RDB Board, RevB  and I was able to boot LS1012ARB from the SD card with yocto build. But for my further development, I am using buildroot and build the buildroot to get my board image (uboot, Image and rootfs in output/image ). But to boot the LS1012ARDB board, I need the kenel.itb file (with Image + kenel.dtb file).  So could any one, let me know the procedure, to generate kenel.itb file with kernel Image + kernel.dtb files.
2 返答(返信)
3,265件の閲覧回数
Pavel
Look at the following pages:
http://code.metager.de/source/xref/denx/u-boot/doc/uImage.FIT/howto.txt
and
http://manpages.ubuntu.com/manpages/xenial/man1/mkimage.1.html
Use the following command:
mkimage -f kernel.its kernel.itb
Pavel Chubakov
3,265件の閲覧回数
srinivasreddyre
Thanks for your inputs.. I was able to generate kernel-ls1012a-rdb.itb and
boot LS1012ARDB with this image..
Procedure to generate kernel-ls1012a-rdb.itb
1. Enable and build to get mkimage and dtc tools
2. Add above tools paths to PATH variable
3. execute $mkimage -f kernel-ls1012a-rdb.its kernel-ls1012a-rdb.itb
