TSN Switch issues on LS1028ardb with OpenIL V1.6
0229ender
Hi everyone~~
I am testing the TSN switch on ls1028ardb with OpenIL V1.6 (Ubuntu).
I used "dscpset" command to map the traffic with dscp value of 40 to cos (queue) 5, which is shown below,
# dscpset --device swp0 --index 40 --cos 5
and the corresponding prompt shown below,
I think reply of -22 means Invalid Argument, but I cannot figure out which argument is invalid.
Then, I test Qbv on swp0 and input "t0 00100000b 1000", but no packet sent from swp0.
I change an input as "t0 00000001b 1000", then the packet can be sent from swp0, and I capture the packet so that I can confirm dscp value is set to 40 properly.
Is there any idea?
Best,
Junhui
ufedor
Please find the attached patch which is present in the dash-linux-devel tree but not in OpenIL.
It fixes the tsntool dscpset command parsing issue in the kernel.
yyu2
Hi Fedor,
I tried your patch for dscp under "openil/output/build/linux-openil-linux201908/net/tsn" to patch the genl_tsn.c.
But after "make" again, the ls1028ardb still reprot "-22" for dscpset command. Perhaps the patch did not take effect. Could you help to advise the correct procedures of patching?
thanks,
   Yi
