T2080 : How to use address sanitizer
搜索替代
646 次查看
tachyon11
According to GCC version, I think that the address sanitizer can be available.
To detecting memory corruption for the costom board, it seems to be so useful.
But  I've not used it ,yet.
https://en.wikipedia.org/wiki/AddressSanitizer
AddressSanitizer (or ASan) is a programming tool that detects memory corruption bugs such as buffer overflows or accesses to a dangling pointer (use-after-free).
AddressSanitizer is based on compiler instrumentation and directly-mapped shadow memory.
AddressSanitizer is currently implemented in Clang (starting from version 3.1[1]) and GCC (starting from version 4.8[2]). On average, the instrumentation increases processing time by about 73% and memory usage by 340%.[3]
In order to compile T2080 system, I've used the next GCC version
powerpc64-fsl-linux-gcc (GCC) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Do you know how to use it ?
Is there a kind of manual for it ?
标记 (2)
434 次查看
r8070z
The GCC 4.8.1 document
https://gcc.gnu.org/onlinedocs/gcc-4.8.1/gcc.pdf
provides the sanitize options and refers to the google wiki documents - see Address Sanitizer
https://github.com/google/sanitizers/wiki/AddressSanitizer
There are also using cases on the web, for example
Compiling with Address Sanitizer (ASAN) with CLANG and with GCC-4.8 · GitHub
