In defconfig,.config below kernel macros seen.
CONFIG_FSL_SDK_DPAA_ETH=y
CONFIG_FSL_DPAA2=y
CONFIG_FSL_DPAA2_ETH=y
CONFIG_FSL_DPAA2_MAC=y
CONFIG_FSL_DPAA2_ETHSW=y
CONFIG_FSL_SDK_DPA=y
Any changes to above macros required in-order to support only DPAA1 as shown below? or no changes required?.
CONFIG_FSL_DPAA=y
CONFIG_FSL_FMAN=y
CONFIG_FSL_DPAA1_MAC=y
CONFIG_FSL_DPAA1_ETHSW=y
I assume that you are using Linux source code from LSDK 21.08, please configure Linux Kernel as the following.
CONFIG_FSL_SDK_FMAN=y
CONFIG_FSL_SDK_BMAN=y
CONFIG_FSL_SDK_QMAN=y
