[LS1046A][DPAA1] Failed to apply DPAA manipulations header
853件の閲覧回数
alance
We’d like to use DPAA to update the VLAN header but failed to apply the rule. From the error, it indicates Advanced-offload must be enabled. Could you provide us how to enable DPAA Advanced-offload? Thanks.
The fmc result:
The fmc rule:
848件の閲覧回数
yipingwang
The error: “Advanced-offload must be enabled”, comes from the fact that header manipulations do not work if we do not have offload_support enabled.
Please change the config file and add the offload attribute to engine tag. Like this:
<engine name="fm0" offload="1">
849件の閲覧回数
yipingwang
