LS1046A 1588 timer
LS1046A 1588 timer
hongyuanz
What is the difference between these..?
1 etsec-ptp, 2dpaa-fman-ptp-time, 3 dpaa2-ptp, 4 enetc-ptp
yipingwang
etsec-ptp is used on LS1021A platform.
dpaa-fman-ptp-time is used on LS1043A and LS1046A platform.
dpaa2-ptp is used on LS1088A, LS2088A and LX2160A platforms.
enetc-ptp is used on LS1028A platform.
hongyuanz
How to configure Freescale QorIQ 1588 timer based PTP clock ,  It is through dts. . ?
yipingwang
Just enable drivers/ptp/ptp_qoriq.c, enable CONFIG_PTP_1588_CLOCK_QORIQ in Kernel configuration file.
hongyuanz
dpaa-fman-ptp-time is used on LS1046A platform,
FMan Real Time Clock support  Is there any introduction to the use of related documents .. ?
yipingwang
Please refer to Documentation/devicetree/bindings/ptp/ptp-qoriq.txt in Linux Kernel source code.
