LS1012A soft reset via memory write
1,384 次查看
nattapongsungch
Hi ,
I tried to do a Soft reset via memory writing from U-boot.
What i have done on U-boot is.
Issue 0x1570204 , Core soft reset enable control register (CORESRENCR)
=> mw 1570204 ffffffff
Issue 0x1570130 , Core0 soft reset register (CORE0_SFT_RST)
=> mw 1570130 ffffffff
Then chip not reset.
I'm not sure it is correct register or soft reset sequence is correct or not.
Thank you,
Nattapong
1,230 次查看
ufedor
It is needed to check that the GIC interrupt mapping is performed correctly.
Please refer to the QorIQ LS1012A Reference Manual, 4.4.2 Core Soft Reset.
