I am facing a problem with the RCW that I put on a QSPI flash.
Something goes wrong on RCW. The board is not booting.
In that way I decide to plug the codewarrior TAP to the board.
I just would like to read the dcfg_ccsr_rstrqpblsr[err_code] register to identify the cause of the RCW failure.
But when I try to establish a connection in that case with codewarrior, it is terminated and I am not able to establish a connection.
It works when I booted with other RCW.
How can I do to have a look on this register through the code warrior tap ?
Have you tried to Attach CodeWarrior - i.e. do not apply reset and execute an initialization script?
