How to cross compile powerpc64(T4240 RDB)
Search instead for
mvicki93
We purchased a T4240 development kit (NXP T4240RDB).
We installed that package on 14.04.1-Ubuntu. I can compile linux and uboot using bitbake for t4240rdb-64b.
When I cross compile a simple .c file with printf for powerpc64 architecture. I face some issues on compile
Error message:
$ powerpc64-fsl-linux-gcc  main.c
main.c:15:19: fatal error: stdio.h: No such file or directory
 #include <stdio.h>
compilation terminated.
How to cross compile for powerpc64 architecture?
Pavel
Use toolchain from Linux SDK BSP for QorIQ processor:
http://www.nxp.com/products/software-and-tools/run-time-software/linux-sdk/linux-sdk-for-qoriq-proce...
NXP offers SDK 2.0-1703 for the T1024RDB board.
This SDK supports toolchain for standalone compiling.
See the Section 3.3.7 (Install the Standalone Toolchain) in the SDK 2.0-1703 documentation:
http://www.nxp.com/assets/documents/data/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
Use similar command sequence for your program compiling:
  1. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
 $ . /opt/fsl-qoriq/2.0/environment-setup-aarch64-fsl-linux
  1. sudo chmod 777 /opt/fsl-qoriq/2.0/environment-setup-aarch64-fsl-linux
  2. source /opt/fsl-qoriq/2.0/environment-setup-aarch64-fsl-linux
Check result of "source" command. Use "$PATH" command. The "source" command should add path to gcc compiler.
You should see similar message:
echo $PATH
bash: /opt/fsl-qoriq/1.9/sysroots/x86_64-fslsdk-linux/usr/bin:/opt/fsl-qoriq/1.9/sysroots/x86_64-fslsdk-linux/usr/bin/powerpc-fsl-linux-gnuspe:
  1. $CC test.c -o test.elf
Pavel Chubakov
mvicki93
Thanks for your email.
On Friday, April 28, 2017, Pavel <admin@community.nxp.com
