When I try to build a non-secure version of the composite image for a LS1043ardb
flexbuilder -i mkfw -b sd -m ls1043ardb -a arm64'
It builds the "ATF version" (secure version), but it then says:
"uboot sdboot on ls1043ardb is not supported"
Hello Thomas Morrison,
Which version SDK are you using?
I execute the following command in LSDK 19.09, I didn't encounter any problem.
$ flex-builder -i mkfw -b sd -m ls1043ardb -a arm64
Would you please attach your whole console log to me to do more investigation?
Yiping
Attached is the build for LSDK 19.09. This shows it building the tfa build (bl2/bl3..etc).
Here are the last few lines of this:
Build ATF for ls1043ardb sdboot in /home/tom/lsdk/build/firmware/atf/ls1043ardb [Done]
make[1]: Leaving directory '/home/tom/lsdk/packages/firmware'
make: Leaving directory '/home/tom/lsdk'
uboot sdboot on ls1043ardb is not supported - one2!
I figured that was coming from Flex-Builder, and put unique error phrase (e.g.: one2!)for each possible exit
It happens inside of the "generate_qoriq_composite_firmware() - on line ~142
if [ ! -f $fipimg ] || [ ! -f $bl2img ]; then
echo ${3} ${2}boot on $1 is not supported - one2! && exit
fi
According to your log, files bl2_sd.pbl and fip_uboot.bin have already existed in folder build/firmware/atf/ls1043ardb/.
Did you modify file configs/board/ls1043ardb/manifest? What's your Linux distribution?
Would you please comment the following lines to check whether the SD firmware image could be generated.
# if [ ! -f $fipimg ] || [ ! -f $bl2img ]; then
# echo ${3} ${2}boot on $1 is not supported! && exit
# fi
Hi Yiping,
Performed tests, here are the results...
1) It seems builds the "secure" image - even if I don't ask for it.
2) I have not modified the manifest
3) Ubuntu 18.04 LTS
4) Edited, and re-ran - it again just built the secure image and nothing else - BUT - I didn't get that error
It seems that the generate composite firmware image doesn't build a non-secure version?
Questions:
a) Is there a way to build the composite firmware image any other way
b) What I really need is to install Linux kernel and rootfs on the SD Card.
So, is there a procedure to install the Linux Image/dtb along with the rootfs
using 'dd' commands (I am currently using this method to install uboot and
microcode on sd card for debug).
Thanks in advance.
Please deploy bl2_sd.pbl at block no. 0x00008 on SD card.
Please deploy fip_uboot.bin at block no. 0x00800 on SD card.
For details, please refer to section "4.2 LSDK memory layout and Userland" in LSDK1909 LSDK user manual.
bl2_sd.pbl contains RCW+PBI+BL2
fip_uboot.bin TF-A FIP image, it contains BL31 +TEE (BL32) + U-Boot.
If ATF version firmware image, u-boot is built with configuration file ls1043ardb_tfa_defconfig, so SD u-boot image u-boot-with-spl.bin is not used.
Please try to use Attach method to debug the bootloader, please refer to IDE configuration in "2. Debug u-boot with CodeWarrior for ARMv8" in https://community.nxp.com/docs/DOC-331981 to configure CodeWarrior IDE to debug the bootloader.
