Adding SJA1000 to CS3 of IFC in T2080qds
次の代わりに検索
905件の閲覧回数
anshulkhare
I have a custom board, which is using t2080qds power pc processor. chip select 0 to 2 are used for various memory and FPGA. The address for those were given in system memory of SDK document. Now I have additional SJA1000 CAN controller connected to chip select 3 (CS3). How to add the address range for the same in device tree.
Also will it not add any conflict to add parallel CAN controller to FPGA on IFC
I am not sure what to add for reg = < 3 ? ?>
Thank you!!
P.S: Do I have to update u-boot too? As I am planning only to use CAN controller only after linux comes up in application. I am using YOCTO!
5 返答(返信)
759件の閲覧回数
anshulkhare
I have configured  CSPR,CSOR and AMASK of IFC for can controller in u-boot. I am confused about FTIM0 - FTIM3 registers.
Can anyone help, how to configure those for general ASIC devices such as SJA1000 ( can controller).
Thanks in advance!!
759件の閲覧回数
anshulkhare
Thank you ufedor‌.
As I mentioned I am using SJA1000 CAN controller, I have enabled SJA1000 driver via menuconfig.
Does it support IFC interface, or I have to write a driver( can I find the driver anywhere else)!
I updated the device tree:
can1: can@3,0 {
                compatible = "nxp,sja1000";
                reg = <3 0x0 0x80>;
                interrupts = <10 8>;
                interrupt_parent = <&mpic>;
                nxp,external-clock-frequency = <8000000>;
Enabled SJA1000 driver!!
I am getting the below error while accessing can1 via socket commands:
    Device "can1"  does not exist
759件の閲覧回数
ufedor
IFC interface can be used to connect the SJA1000.
Interface is a hardware connection, while driver - software.
So driver is also required considering that hardware connection is implemented.
Please refer to the "SJA1000 Stand-alone CAN controller":
https://www.nxp.com/docs/en/application-note/AN97076.pdf
and T2080RM, Chapter 13 Integrated Flash Controller (IFC):
https://www.nxp.com/webapp/Download?colCode=T2080RM
Possible IFC GPCM connection to the SJA1000 is:
IFC_AD0 - AD7
IFC_AD7 - AD0
IFC_OE_B - /RD
IFC_WE0_B - /WR
IFC_AVD - ALE
IFC_CS3_B - /CS
SJA1000 MODE - VDD
759件の閲覧回数
anshulkhare
After dmesg,
I see below error in sja1000_isa : insufficent parameters supplied.
After debugging i found mem[idx] , irq[idx] and port[idx] value is 0.
Driver has MODULE_PARAM_DESC function to pick the arguments via command line.
But my driver has to be loaded statically, so I cant pass arguments. I was expecting it would take the information from device tree.
Am I missing something?
759件の閲覧回数
ufedor
You need to define correct address range for the CS3, for example, in the T2080QDS DTS ranges are as follows:
ranges = <0 0 0xf 0xe8000000 0x08000000
          2 0 0xf 0xff800000 0x00010000
          3 0 0xf 0xffdf0000 0x00008000>;
The "reg" entry contains 3 cells: the chip-select number, the offset, and the length, so in the described case it has to be:
reg = 0 len>.
For the "len" value refer to the SJA1000 Data Sheet.
This is not required.
