rt1170 i2c dma transfer
1,516 次查看
vladimirchernin
Hi!
I have a problem to launch I2c6 by using DMA i dont see what a problem but trasnmit is fail if i dont use DMA everything works in blocking mode. what is wrong in code below?
thanks
void BOARD_LPI2C_Init_DMA(LPI2C_Type *base, uint32_t clkSrc_Hz)
lpi2c_master_config_t lpi2cConfig = {0};
CLOCK_EnableClock(kCLOCK_Lpi2c6);
LPI2C_MasterGetDefaultConfig(&lpi2cConfig);
lpi2cConfig.debugEnable = false;
lpi2cConfig.ignoreAck = false;
lpi2cConfig.pinConfig = kLPI2C_2PinOpenDrain;
lpi2cConfig.baudRate_Hz = 1000000U;
lpi2cConfig.busIdleTimeout_ns = 0;
lpi2cConfig.pinLowTimeout_ns = 0;
lpi2cConfig.sdaGlitchFilterWidth_ns = 0;
lpi2cConfig.sclGlitchFilterWidth_ns = 0;
LPI2C_MasterInit(base, &lpi2cConfig, clkSrc_Hz);
//LPI2C_MasterInit(base, &lpi2cConfig, CLOCK_GetFreq(kCLOCK_Lpi2c6));
// LPI2C_DMAMUX_Init();
// Create EDMA handle
edma_handle_t edmaHandle;
EDMA_CreateHandle(&g_edma_tx_handle, DMA0, 0);
LPI2C_MasterCreateEDMAHandle(base, &g_edma_handle, &g_edma_tx_handle, &g_edma_tx_handle,lpi2c_master_edma_transfer_callback,NULL);
status_t BOARD_LPI2C_Send_DMA(LPI2C_Type *base,
uint8_t deviceAddress,
uint32_t subAddress,
uint8_t subAddressSize,
uint8_t *txBuff,
uint8_t txBuffSize)
lpi2c_master_transfer_t transfer;
transfer.slaveAddress = deviceAddress;
transfer.direction = kLPI2C_Write;
transfer.subaddress = subAddress;
transfer.subaddressSize = subAddressSize;
transfer.data = txBuff;
transfer.dataSize = txBuffSize;
transfer.flags = kLPI2C_TransferDefaultFlag;
status_t status = LPI2C_MasterTransferEDMA(base, &g_edma_handle, &transfer);
return status;
status_t BOARD_LPI2C_Receive_DMA(LPI2C_Type *base,
uint8_t *rxBuff,
uint8_t rxBuffSize)
transfer.direction = kLPI2C_Read;
transfer.data = rxBuff;
transfer.dataSize = rxBuffSize;
return status;
标记 (1)
9 回复数
1,329 次查看
Pavel_Hernandez
Hello, I'm following your case, let me review more information, when I have more details, I will contact you.
Pavel
1,350 次查看
vladimirchernin
hi!
Its still doesnt  work may be i need to set specific DMA channel for i2c6?
its fails to write to i2c with
thanks
#define EXAMPLE_LPI2C_DMAMUX_BASEADDR (DMAMUX0)
#define EXAMPLE_LPI2C_DMA_BASEADDR (DMA0)
DMAMUX_Init(EXAMPLE_LPI2C_DMAMUX_BASEADDR);
edma_config_t edmaConfig = {0};
EDMA_GetDefaultConfig(&edmaConfig);
EDMA_Init(EXAMPLE_LPI2C_DMA_BASEADDR, &edmaConfig);
please see the code
1,318 次查看
Pavel_Hernandez
Hello, I recommend using the example of the RT1050 in the driver files and migrating this to the RT1170 there are examples of I2C with DMA. This will be more familiar with the NXP driver configuration.
Pavel
966 次查看
vladimirchernin
hi!
i dont see examples in 1176 sdk can you send me  how to work with edma i2c rt1176 i dont have access on nxp site
thanks
964 次查看
vladimirchernin
967 次查看
vladimirchernin
rt1050 not availible
1,495 次查看
Pavel_Hernandez
I review your code seems good in the configuration of the driver, but you are missing the configuration of the DMA, I suggest reviewing the example of the SDK forget more details,
If you have more related questions, please let me know.
Pavel
1,488 次查看
vladimirchernin
hi!
There is nxp driver fsl_lpi2c_edma what  else  i need  to config for DMA ?
please explain
thank you
1,462 次查看
Pavel_Hernandez
There is some configuration for the DMA, please review the example.
Pavel
