USB MSC
Search instead for
USB MSC
AsafTv
I use MK64FN1m0XXX12 device.
I Implemented USB MSC example in my code.
I Try to read or write 16Mbytes File from it but is to slowly...
I Try to increase the buffers inside the example disk.c but also is to slowly...
advice
nxf77486
Hello @AsafTv ,
Can you please provide the exact example of the SDK USB MSC you are currently testing. Also I attached a community post of what I believe is a similar problem, if not please let me know in order to find the right solution for you.
USB MSC Data Rate on FRDM-K64F
AsafTv
I use example from the SDK using MCUXpresso to generate it.
 I increase the buffer for read and write to 64 * 512 and I'm not see changes.
it take to write file of 16Mbytes 28 second
nxf77486
Hello @AsafTv
Can you please help me with the name of the example of the SDK you are currently using (see image attached for reference).
Also if you have a program for USB descriptor it will be helpful to understand better the situation. I usually use the USB Device Tree Viewer.
