PE fails to generate code if the project path contains parentheses (CW10.2)
1,548 次查看
Ainslie
Is this a PE issue or an eclipse issue, as I am porting over from V7.1.
ie.  \firmware\(DC00521)\main\ProcessorExpert.pe
标记 (1)
973 次查看
BlackNight
this is a PE issue, it reports:
Description    Resource    Path    Location    Type
ERROR: Project path contains unsupported characters - brackets    test(pe)        Cpu    Processor Expert Problem
Not sure why this is not supported, but I pass this to the engineering team.
Normal CodeWarrior/Eclipse projects can have () in the path. I know that there are things like ';' not supported, btw.
BK
4 回复数
974 次查看
BlackNight
BK
973 次查看
Robinwithu
Senior Contributor I
Hello Erich,
I am also getting the same error
for MC9S08RN8 µC for Codewarrior 10.5, have you got the answer?
Robin
973 次查看
BlackNight
Hi Robin,
to my understanding this will not be changed, so you have to remove the (...) from your path. Would that be an issue?
Erich
973 次查看
Robinwithu
Thank you Erich.
Kind Regards
Robin
