OC_SetCompareValue(.., OC_ABSOLUTE_VALUE) in oc_pal component
523件の閲覧回数
CharlesAlbert
I there,
I try to use a FTM counter to generate interruption at a desired time. Each time the interrup falls, I want to settle the next time (relative) it raises again. Interrupt can also be forced asynchronuously by setting the relative time very close to the current counter value.
I need two channels like because I want this beavior 2 times, I used OC_pal with a disable output.
This normally allows me to generate interrupt when CnV value matches counter values CNT. Counter values shall count up to Mod values and restart (0-0xFFFF) continuously.
I did the following test with a counter at 1Mhz, at each interrupt I toggle a pin to check timing at scope.
- I use in the interrupt handler, OC_SetCompareValue(.., OC_ABSOLUTE_VALUE) to set a fixed value of 1000. I expect a period of 65,535 ms (one match per period of timer). Instead I have a period of arround 1ms? Why?
Is the CNT reload initial value when loading CnV register? how to avoid that? (I want the counter to always count).
Thanks a lot,
474件の閲覧回数
CharlesAlbert
I found my issue: OC_SetCompareValue() call FTM_DRV_UpdateOutputCompareChannel(..) with the software trigger as TRUE! I change to not use the SW trigger and then I have the behavior I expect!
Thx.
5 返答(返信)
475件の閲覧回数
CharlesAlbert
Thx.
506件の閲覧回数
ZhangJennie
Hi CharlesAlbert
Please tell us your chip part number thus we can assign right engineer for your issue.
Jun Zhang
473件の閲覧回数
CharlesAlbert
Please see my post below. I found that the SW triggers used in OC_SetCompareValue() created my issue.
520件の閲覧回数
CharlesAlbert
Found it myself
521件の閲覧回数
CharlesAlbert
I change CNTIN value and it seems used at load of CnV.. How to avoid that reload?
