Hi everyone,
I need some help,
I'm working on a software and I need to separate some software item each other.
So i'm thinking about different section in flash memory. But, I need to protect this section, software item A should not interact with software item B unless by getter and setter.
So I understand region configuration and MPU configuration but I don't understand Access Permission. (Priviliged and Unprivileged)
Can someone explain me this or some code example, documentation etc..
Thank you for the help,
Morgan
Hi @morganRo ,
You can refer to this guide. RT device follow this guide. But it seems there isn't other document or example.
Jing
I don't figured out how to active privileged / unprivileged permissions. For example, if i split SRAM_DTC in two section, how can I protection write between this two section?
Can you tell us which MCU are you using please?
I'm using the IMXRT1061 MCU. Actually, I figured out how to deal with. But i still try to implement protection memory, RO in flash (split in three section) is OK. But now I want to mirror in RAM to implement correctly variable. Thanks, Morgan
