I am working linux kernel 3.2.54, while I connect the USB serial cable the kernel panics and the system restarts. The host controller I am using for the USB is xHCI. The serial cable which I am using is from cablecreation with product id is 23a3 and vendor id is 067b.
I have added the product id and vendor id using
echo 067b 23a0 > /sys/bus/usb-serial/driver/pl2303/new_id
I am attaching the logs of kernel panic.
Hi @Kathan
What's your chip part number? Please let us know thus we can assign right engineer for this question.
Jun Zhang
Hi @ZhangJennie ,
Thanks for your response
Below mentioned is the chip part number
LS1024ASN7JLA NXP Mindspeed
The kernel you are using is not supported by nxp, you will have performance with supported kernel please check it.
