Android 13 Source code - Build error
Adi99
I have downloaded source code from nxp website for imx8mp - Android 13 code.
but when I start to build bootloader for imx8mp-evk user debug image i got below error .
Compiling mkimage_imx8
PLAT=imx8mp HDMI=no
make[2]: *** No rule to make target 'lpddr4_pmu_train_1d_imem_202006.bin', needed by 'u-boot-spl-ddr.bin'. Stop.
make[2]: *** Waiting for unfinished jobs....
cc -O2 -Wall -std=c99 -static ../iMX8M/mkimage_imx8.c -o mkimage_imx8 -lz
../iMX8M/mkimage_imx8.c: In function ‘copy_file.constprop’:
../iMX8M/mkimage_imx8.c:345:21: warning: ‘write’ reading 5 bytes from a region of size 4 [-Wstringop-overread]
345 | if (write(ifd, (char *)&zero, 4-tail) != 4-tail) {
../iMX8M/mkimage_imx8.c:303:13: note: source object ‘zero’ of size 4
303 | int zero = 0;
In file included from ../iMX8M/mkimage_imx8.c:24:
/usr/include/unistd.h:378:16: note: in a call to function ‘write’ declared with attribute ‘access (read_only, 2, 3)’
378 | extern ssize_t write (int __fd, const void *__buf, size_t __n) __wur
make[1]: *** [Makefile:23: flash_evk] Error 2
what is the problem?
giampietroghizz
hi,
I am trying to do the same thing.
I am following the directions given in this document:
https://www.nxp.com/docs/en/user-guide/Android_Auto_User's_Guide.pdf
however i see that the “build” folder is not created with the envsetup.sh file
could you give me some pointers?
thanks
giampietroghizz
i solved the problem: it was a misconfiguration of the enterprise network architecture
Adi99
HI @Zhiming_Liu
1. source build/envsetup.sh
export CLANG_PATH=/opt/prebuilt-android-clang
export AARCH64_GCC_CROSS_COMPILE=/opt/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-
2. lunch evk_8mp-userdebug
3. ./imx-make.sh bootloader -j24
steps i have checked is up to date. but it will throw same error.
303 | int zero = 0;
Zhiming_Liu
Do you still have this issue?
Maybe your repo sync is not complete and miss this firmware.
Adi99
Hi @Zhiming_Liu
error: bootable/libbootloader/: platform/bootable/libbootloader checkout 3dccc2dc55b1982668c268cefc1f648e489519a4
error: Cannot checkout platform/bootable/libbootloader
error: Unable to fully sync the tree.
error: Checking out local projects failed.
Failing repos:
Try re-running with "-j1 --fail-fast" to exit at the first error.
repo sync fialure in bootloader part. I have tried 4 to 5 times repo sync -j1 --fail-fast but same error is throwing.
what is the solution for that?
Zhiming_Liu
@Adi99
Try to delete the repo workspace and repo init again.
Adi99
Hi @Zhiming_Liu
yes same error getting. again check repo sync and update you.
Thanks.
Zhiming_Liu
@Adi99
Please share your detailed steps. It seems that the product name you input is not correct.The correct command should be lunch evk8_mp-userdebug
Adi99
Hi @Zhiming_Liu
i have solved this issue. I have re downloaded again repo and follow that NXP guide its works successfully.
