Android 13 Source code - Build error
Adi99
I have downloaded source code from nxp website for imx8mp - Android 13 code.
but when I start to build bootloader for imx8mp-evk user debug image i got below error .
Compiling mkimage_imx8
PLAT=imx8mp HDMI=no
make[2]: *** No rule to make target 'lpddr4_pmu_train_1d_imem_202006.bin', needed by 'u-boot-spl-ddr.bin'. Stop.
make[2]: *** Waiting for unfinished jobs....
cc -O2 -Wall -std=c99 -static ../iMX8M/mkimage_imx8.c -o mkimage_imx8 -lz
../iMX8M/mkimage_imx8.c: In function ‘copy_file.constprop’:
../iMX8M/mkimage_imx8.c:345:21: warning: ‘write’ reading 5 bytes from a region of size 4 [-Wstringop-overread]
345 | if (write(ifd, (char *)&zero, 4-tail) != 4-tail) {
../iMX8M/mkimage_imx8.c:303:13: note: source object ‘zero’ of size 4
303 | int zero = 0;
In file included from ../iMX8M/mkimage_imx8.c:24:
/usr/include/unistd.h:378:16: note: in a call to function ‘write’ declared with attribute ‘access (read_only, 2, 3)’
378 | extern ssize_t write (int __fd, const void *__buf, size_t __n) __wur
make[1]: *** [Makefile:23: flash_evk] Error 2
what is the problem?
giampietroghizz
hi,
I am trying to do the same thing.
I am following the directions given in this document:
https://www.nxp.com/docs/en/user-guide/Android_Auto_User's_Guide.pdf
however i see that the “build” folder is not created with the envsetup.sh file
could you give me some pointers?
thanks
giampietroghizz
i solved the problem: it was a misconfiguration of the enterprise network architecture
zhangzm
How did you solve it?
thanks
giampietroghizz
The problem was in the download phase of the android source code. The corporate IT department had applied restrictions, so the source code had not been downloaded correctly. Once these restrictions were removed from the firewall by the IT department, I was able to do the build correctly. I hope I was of some help.
zhangzm
OK. Thanks!
Adi99
HI @Zhiming_Liu
1. source build/envsetup.sh
export CLANG_PATH=/opt/prebuilt-android-clang
export AARCH64_GCC_CROSS_COMPILE=/opt/gcc-arm-9.2-2019.12-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-
2. lunch evk_8mp-userdebug
3. ./imx-make.sh bootloader -j24
steps i have checked is up to date. but it will throw same error.
303 | int zero = 0;
Zhiming_Liu
Do you still have this issue?
Maybe your repo sync is not complete and miss this firmware.
Adi99
Hi @Zhiming_Liu
error: bootable/libbootloader/: platform/bootable/libbootloader checkout 3dccc2dc55b1982668c268cefc1f648e489519a4
error: Cannot checkout platform/bootable/libbootloader
error: Unable to fully sync the tree.
error: Checking out local projects failed.
Failing repos:
Try re-running with "-j1 --fail-fast" to exit at the first error.
repo sync fialure in bootloader part. I have tried 4 to 5 times repo sync -j1 --fail-fast but same error is throwing.
what is the solution for that?
Zhiming_Liu
@Adi99
Try to delete the repo workspace and repo init again.
Adi99
Hi @Zhiming_Liu
yes same error getting. again check repo sync and update you.
Thanks.
Zhiming_Liu
@Adi99
Please share your detailed steps. It seems that the product name you input is not correct.The correct command should be lunch evk8_mp-userdebug
Adi99
Hi @Zhiming_Liu
i have solved this issue. I have re downloaded again repo and follow that NXP guide its works successfully.
