I read the question/solution about QM version VR5510 running state.
https://community.nxp.com/t5/Other-NXP-Products/How-to-make-PMIC-as-NORMAL-FS/m-p/1487114
At the solution, TechSuppot said that QM version VR5510 can not enter NORMAL_FS.
It means that QM version VR5510 running state is INIT_FS.
if QM version VR5510 running state is INIT_FS state, I wonder whether INIT_FS register can be configured anytime.
Using QM VR5510(MVR5510AMMA4ES) and S32G2 M-core, when I configured INIF_FS register(FS_I_SAFE_INPUTS/TIMING_WINDOW_STBY) after 1024 ms from power-on, INIF_FS register was configured normally.
I wonder INIT_FS registers initialization time for QM VR5510.
Solved! Go to Solution.
Thank you for using the NXP community.
There is no maximum configuration time of INIT_FS for QM VR5510 device. No WD refresh is needed for QM part.
Standby mode can also be entered in INIT_FS state.
You can ignore the FS states after INIT_FS state.
I hope this information helps.
David
I hope all is great with you. Thank you for using the NXP communities.
You are correct, after POR or a wake-up from Standby mode or Deep Sleep mode, when the RSTB pin is released, the Fail-Safe State Machine enters into the INIT_FS phase for initialization.
Please find further information about the writing process at chapter 22.3 from datasheet.
David
Thank you for the explanation.
My question is What is QM VR5510 maximum configuration time of INIT_FS registers(FS_I_xx register).
For ASIL level VR5510, INIT_FS registers maximum configuration time is Watchdog Init Timeout(WD_INIT_TIME_OTP) in the INIT_FS state.
What is the QM VR5510 INIT_FS registers maximum configuration time?
Is it Watchdog Init Timeout(WD_INIT_TIME_OTP) or is there no maximum configuration time?
David
Thank you for the answer.
