Power up Ramp
Power up Ramp
1,011 次查看
bettinawyss
I would like to use PF8200 together with PolarFire FPGA in a project. However, I noticed that the power ramp up times are slightly outside the specifications of PolarFire (200us). Is there a way to somehow get longer ramp up times?
Thank you in advance
Betty
999 次查看
bettinawyss
Yes exactly. E.g: the start up ramp of the voltage regulator output should take at least 200us to go from 0 to 1V.
994 次查看
guoweisun
For the slew rate time which can't modify for the output regulators.
1,004 次查看
guoweisun
Do you mean the start up time?do you need longer than 200us of PMIC?
