PWM23(Output polarity Inverted) channel masked,PWM23 output 1.
Can PWM23 output 0 ( PWM23 Output polarity Inverted & channel masked )?
And what should I do ?
Thanks.
Solved! Go to Solution.
Pls refer to the above figure, in default, the POLA bit is cleared, in the case, if you set the MASK bit, PWM_A output signal will be logic 0.
If the POLA is set, in the case, if you set the MASK bit, PWM_A output signal will be logic 1.
The only way I think is that you clear the IPOL bit before you set mask bit so that the PWM_A output signal will be logic 0 after masking.
Hope it can help you
XiangJun Rong
XiangJun Rong
Thanks for your advice .
when set PWM1A Output polarity Inverted:
PWMA->SM1OCTRL |=0X0400; // PWM1A Output polarity Inverted
We write the MASK register to mask the PWM signals .
The PWM1A output always high ( 1 logic ).
Hi Zhang,
Could you please specify which part number is your question related to?
Tomas
MC56F83763
Thanks for your reminder .
Hi, Zhang,
Of course, you can write the MASK register to mask the PWM signals. If you want to update the PWM signals immediately after you write, pls set the corresponding UPDATE_MASK bit, then write the corresponding MASKA, MASKB or MASKX, the corresponding PWMA_xA, PWMA_xB, PWMA_xX will update immediately.
XiangJun Rong
