FS26 does not reset when it is supposed to
492件の閲覧回数
Albatros
I am using Sbc_fs26_example_HLD_S32K344 example code. I can successfully drive the FS26 into normal mode. However, when FS26 does not reach to my microcontroller (S32K344) it does not reset my board. For example, when I create a while loop, fs26 is supposed to reset my board. Why it does not reset my board?
Note : When i read the value of WD_FS_REACTION[1:0] bits i saw that it is 2.
3 返答(返信)
475件の閲覧回数
guoweisun
For your while loop,what's it function? why do you need reset your board?do you mean reset by RSTB pin?
432件の閲覧回数
Albatros
With a while loop, I tried to act like my code was stuck somewhere. I expected fs26 to reset the board in that time but it didn't.
423件の閲覧回数
guoweisun
You can descript more detail for your operation ,for example the show the states of SBC,which registers did you set?Why need reset SBC and  what condition under reset SBC?
